Removing the Horizontal Stabilizer and Wings on a Sonex
Postby JMJeakle » Fri Oct 14, 2022 11:43 pm
Can anyone give me information on the removal of the Horizontal Stabilizer and Wings for transport?
JMJeakle
Re: Removing the Horizontal Stabilizer and Wings on a Sonex
Postby Bryan Cotton » Sat Oct 15, 2022 12:37 am
Check out the Sonex instruction sheets:
https://www.sonexaircraft.com/instruction-sheets/
In particular the wing removal instructions are here:
https://www.sonexaircraft.com/documents ... nstall.pdf
I built a Waiex so I can't give any advice on the horizontal stab. The Waiex tail would not be something I'd want to take off. Can you get by if you pull the fiberglass tips? That's just drilling out rivets.
Postby sonex892. » Sat Oct 15, 2022 3:33 am
The rudder and vertical fin need to be removed prior to the horizontal. The piano hinges if built per plans can be a pain to remove. You will require a way to punch the pins out far enough to grab them. Apart from disconnecting the control horn connections will need to remove the fillet fairings and 2 inspection plates, there are a bunch of 3/16 and 4 × 1/4 bolts mostly in awkward places.
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby JMJeakle » Sat Oct 15, 2022 3:55 pm
Thanks for the replies. Still looking for instructions for install or removal of the horizontal Stabilizer.
JMJeakle
Postby Skippydiesel » Sat Oct 15, 2022 6:13 pm
JMJeakle wrote:Thanks for the replies. Still looking for instructions for install or removal of the horizontal Stabilizer.
Me too!
Skippydiesel
Postby XenosN42 » Sat Oct 15, 2022 6:18 pm
The horizonal stabilizer was NOT designed to be removable for transport. To remove it you'll need to carefully study the plans and reverse engineer the installation steps. It won't be easy.
-- Michael
OneX N169XE
XenosN42
Postby JMJeakle » Sat Oct 15, 2022 10:26 pm
Thank you. Looks like I will have to build a cradle to hold it at an angle for transport. Thanks again.
JMJeakle
Postby sonex892. » Sun Oct 16, 2022 4:01 am
JMJeakle wrote:Thank you. Looks like I will have to build a cradle to hold it at an angle for transport. Thanks again.
If the fibreglass tips are riveted with aluminium rivets? They would be relatively easily drilled out. At a guess, that would reduce the span by about 7 or 8 inches. If they have been fastened as per the plans with the stainless rivets, it would possibly easier to remove the tail.
How I know. I foolishly followed the plans and installed stainless rivets. I later had to remove the tips to repair hangar rash. Mine now has aluminium rivets holding the tips in place.
Sonex kit 2010
sonex892.
Postby Skippydiesel » Thu Oct 20, 2022 4:51 am
I am about to install the empennage on my Sonex Legacy - all tips & suggestions will be much appreciated.
Skippydiesel
