Glareshield Access panel
Postby gknowles » Wed Aug 17, 2022 11:01 am
Hi all,
I'm thinking of adding a hinged access "trap door" to the aft center section of my glareshield. The plane was built years ago and unfortunately without much thought given to easy access to wiring and the back of instruments. It would be between the gas tank and the instrument panel. Before I proceed, just wondering if anyone has experience, and advice, doing such a thing
Garth
Sonex 832
gknowles
Re: Glareshield Access panel
Postby trwolf » Mon Sep 12, 2022 1:11 pm
It is a bit more work, but I installed a hinge on the lower portion of the panel and life is so so good by removing just 6 screws from the top of the panel. even an access panel on the top will give you only so much access and still require a good deal of crawling underneath. I posted some pics on the Xenos category some years ago.
trwolf
Return to Sonex
