Cowling Fixings
Re: Cowling Fixings
Postby racaldwell » Thu May 26, 2022 6:10 pm
Or you can have your son get out the cloth & resin and make an engine cooling plenum. Then little stress on the cowl fasteners.
This one did not take very long to make.
Rick Caldwell
Xenos 0057
CAMIT 3300
Engine Cooling Plenum Sm.jpg (152.81 KiB) Viewed 665 times
racaldwell
Re: Cowling Fixings
Postby Skippydiesel » Fri May 27, 2022 2:35 am
racaldwell wrote:Or you can have your son get out the cloth & resin and make an engine cooling plenum. Then little stress on the cowl fasteners.
Rick Caldwell
Xenos 0057
CAMIT 3300
Looks great Rick.
Unfortunately wont help my installation. My coolant radiate is located at the bottom of the firewall. It depends on getting a good air flow from within the cowling. As totally experimental & yet to fly, I am assuming that I must try to minimise air leaking out of the cowling. (would post photo's but have had no luck in that area.)
You can check out the build on https://webuildplanes.com/cliff-jarvis/
Skippydiesel
Users browsing this forum: Google Adsense [Bot] and 6 guests
