Skippydiesel wrote:Making a paper cone, to use as a pattern for my felt draft excluder idea should be easy.
I can make a cone okay, even checked out some "How To..." videos (there are heaps) but do you think I can make one that has just the right dimensions??? Nooooo!
FRUSTRATION!!! - just have to make more cones, in the hope one comes close to my careful measurements.
peter anson wrote:I didn't try to seal the aileron pushrod holes although there is plenty of air enters through those holes. I sealed along the side and back of the seats with soft panels that velcro to the seat pan.
Air then came through the joystick cutout in the seat pan but a boot fixed that. The flaps have the added advantage of stopping things from falling under the seat where they might interfere with control movement.
Pteer
GraemeSmith wrote:Skippydiesel wrote:Making a paper cone, to use as a pattern for my felt draft excluder idea should be easy.
Best I can describe - you need to tilt the cone forward - quite significantly so the center axis of the cone matches the line of the stick when pushed full forward. Then cut the base obliquely at the base to match the seat pan.
The cone also needs to be "longer" than the stick by almost twice the stick length - so when fitted to the stick and squashed down - you get the amount of material you need to allow it to flex in all directions. So the cone is taller and "pointier" than you might imagine it should be.
