by 13brv3 » Sun May 01, 2022 12:15 pm
Correct that forcing any of these canopy or windscreen materials to conform to a shape they don't want to be in is asking for trouble. Some redirection is always necessary, but if you have a big gap, and think it can just be pulled down with screws, there's a good chance it won't be a good idea in the long run.
Cracks will form anywhere there's an opportunity, so cut edges, or drilled holes have to be smooth. If there were no stress, it's unlikely they'd crack, but with stress, and any rough edge... For cut edges, smooth them very well with fine sandpaper to round and smooth the corners. For holes, do the best you can with a tool that will put a smooth chamfer, like a unibit.
The final bit of advice that I haven't seen mentioned is hole size. Always enlarge the holes over the size of the fasteners. Canopies have a good bit of thermal expansion and contraction, and that will cause it to push and pull on the holes. It's best to give them some room to allow movement. I personally didn't use countersunk holes on my canopy for that reason, since I HATE fitting canopies.
Sadly, no matter what you do, canopies will sometimes crack. The RV guys got all crazy with using a sealant to glue them on, so there are no holes for fasteners. Yep, they still crack. I hate canopies...
Rusty
Rusty
Onex- Rotax 912 (130 hours and counting)
Fixed wing, gyroplane, A&P
