wlarson861 wrote:Many solvents and especially auto gas will crack Lexan.
Bryan Cotton wrote:Did you polish the edges/corners? If not it can be prone to crack when you bend it.
N43WX wrote:Not quite to this point, but can someone clarify the polishing of lexan corners? I haven't heard this before. Is it essentially just deburring? Scotchbrite or other? Not polishing as in using any chemicals?
DCASonex wrote:If cracks are radiating from drilled holes, might be due to lubricant on drill bit. make sure drill bits are washed clean of any lubricant or solvent when drilling lexan.
