Bryan Cotton wrote:If they made one rod end left hand threads, then it's easy to adjust. You twist the rod to lengthen or shorten.
DCASonex wrote:Bryan Cotton wrote:If they made one rod end left hand threads, then it's easy to adjust. You twist the rod to lengthen or shorten.
If anyone does build it with right and left hand threads, like an extra long turnbuckle, be sure to safety wire those ends. That "easy" adjustment is not something you want happening in flight.
David A
David A
peter anson wrote:It is possible to get nuts that have a lock wire hole and I have seen rod ends that are drilled for lock wiring but it's a sure bet that your aircraft doesn't have that type. All my control rods are fitted with right hand rod ends at both ends and just locked with a lock nut. It's possible to check many of them when doing the daily pre-flight and for anything to shift, two lock nuts must come loose. I don't recall it being difficult to rig. Clamp the aileron in place; set the bell crank at the correct angle and adjust the control rod ends until the holes line up.
