F16-02 and 05 Fwd Tunnel Z measurement question
Postby Barry63 » Thu Feb 10, 2022 10:55 pm
In the process of fabing F16-02 Fwd Tunnel Zee and F16-05 Aft Angle. Looking at the measurements for the wing alignment holes, it appears to me that those 3 holes are measured from inside the lower bend, not from the outside edge of the part as is usually the case. Am I reading that correctly? Since the material thickness is .032, in order to be able to measure from the outside surface, I just need to add 1/32" to each measurement. I am planning on drilling both of these parts together at the same time for maximum accuracy.
Barry Leap
Mostly scratchbuild Sonex T/D
Jabiru 2200?
Barry63
Re: F16-02 and 05 Fwd Tunnel Z measurement question
Postby Bryan Cotton » Thu Feb 10, 2022 11:28 pm
I think the tips of the arrows are obscured by the dashed line. Look at the line that extends from the left bottom to the end view - where the 8 25/32" measurement is for example.
Postby Barry63 » Sun Feb 13, 2022 8:06 am
Thanks, Bryan. After looking closer and taking some measurements on the plans, you are correct. Finished up the Fwd Zee yesterday.
Barry Leap
Jabiru 2200?
Barry63
