VICTORY!!! For any future builders that may run across this problem I'll expand: (tail was not permanently secured or drilled to the empennage)
One of those moments that I'm happy I stepped away to make sure I wasn't missing something. The empennage and stabilizers were well constructed by the previous kit owner. In reviewing plan T01 I found a few things that I hoped would fix my elevator control horn issues and I'm so happy to say that they did!!!
-Important measurement on View-A on how far in on mounting location the horizontal stabilizer should be away from the vertical stab. I was 1/4" short on this measurement.
-Important note View-A about adjusting horizontal stabilizer location to allow full elevator travel.
How I got stuck was the vertical stabilizer forward attach fitting/spar was slightly overbent so I incorrectly perceived that as the limiting factor of how far the horizontal stabilizer could go in. Also, the skins on the horizontal stabilizer were previously well trimmed and bottoming out on the empennage.
Solution:
-Remove vertical stabilizer and temporarily forget about fitting that, focus on the horizontal stabilizer fit and measurements.
-Mark and CAREFULLY file the forward/nose part of the horizontal stabilizer so it would seat more forward. I installed and removed the stab numerous times, taking small amounts of material each time. I lifted up stabilizer a few times during my marking process since there are a few pesky rivets on the fuselage skin that I didn't want file out for until I had the nose seating correct since the location would change as I improved the seating.
-After the nose seating was correct I made some small relief files for the fuselage rivet heads.
-Achieved the golden 3 1/4" measurement
-Filed out the underside skins. For the trailing edge I had to remove 4 rivets in each corner to lift the skin and trim it. Getting the rivet tails out of the stabilizer was not easy :)
-Increased the notch in the turtle deck for the vertical stabilizer forward attach fitting/spar.
-Test fit vertical and horizontal stabilizer, confirmed the vertical stabilizer forward attach fitting was incorrectly limiting the horizontal stabilizer from reaching the expected location.
-Put the vertical stabilizer forward attach fitting in a big table mounted vise as far down as I could and reduced the bend angle.
-Reinstalled and happy place! The horn was not unexpectedly bottoming out except at the very top of travel. Filed out just a tiny bit of skin on the vertical stabilizer sides.
- before (simulated)
- 20161221_205309.jpg (33.57 KiB) Viewed 4034 times
- after
- 20161221_205254.jpg (32.99 KiB) Viewed 4034 times
