fuel tank amount
fuel tank amount
Postby SonexEZ » Thu Mar 24, 2016 7:32 pm
I have a trigear normal size tires on the main and a little larger on the nose wheel . it had all large tires and they where new . but I wanted to install wheel covers so had to go back to original size . what I am wondering dose anyone get 15-16 gallons if fuel in there tank . if I push it I can get 14.4 gallons .
SonexEZ
Re: fuel tank amount
Postby vwglenn » Fri Mar 25, 2016 10:17 am
I managed to fill my tail dragger up after I did some maintenance on the tank. Had 16 gallons in it till I lifted the tailwheel in the hangar and a bunch poured out of the vent.
Glenn
Sonex #600
N889AP
vwglenn
Postby Jim B » Sat Mar 26, 2016 7:26 am
I can get 15 gallons in mine. I have a fuel flow indicator installed which is very accurate and a capacitance type sensor fuel guage couple to my EIS 4000. Both are calibrated to indicate 15 gallons when full. I depend on my fuel flow indicator for an accurate indicator of fuel left. The capacitance fuel guage varies as the level in the tank varies due to the shape of the tank. I have always used 100LL and nothing but 100LL. The capacitance sensor is very sensitive to different specific gravity fuel. I learned that from a prior plane that I was flying on Amoco 93 without ethanol. Then Amoco 93 with ethanol was introduce and my first fill up with it screwed my calibration up. I had to empty the tank and do another calibration with ethanol free fuel and never tried the ethanol fuel again.
Jim Ballenger
snx760/jabiru2200
first flight Sept 2009
Ocala,Fl
Jim B
Postby peter anson » Sat Mar 26, 2016 8:27 am
When I originally calibrated my level gauge the tank took 61 litres (16 gallons). If you have a top fuel vent you should be able to completely fill the tank of a tail-dragger. Just recently the fuel cap has started leaking when the tank is really full so it looks like a new Rodger Connolly type cap is in my future. I'm not familiar with the EIS 4000, but with the Stratomaster the fuel level can be calibrated at intermediate stages so it is fairly accurate through the whole range.
Sonex 894
Postby planeolbob » Sat Mar 26, 2016 9:51 am
Hi everyone,
With my fuel vent as shown
https://www.flickr.com/photos/32288421@ ... 9998890631
I get 17 gal in my tank.
Bob
planeolbob
