SonexEZ wrote:Hi guy's i got my aircraft over to the airport and having problems getting the wing bolts in am i missing something ? the wings where on this aircraft once before , so i know they should fit , :?:
sonex892. wrote:SonexEZ wrote:Hi guy's i got my aircraft over to the airport and having problems getting the wing bolts in am i missing something ? the wings where on this aircraft once before , so i know they should fit , :?:
Are you doing it with the rubber trim installed? Getting my wings on seems impossible without removing the rubber trim. I need to re install it after bolting the wings up.
Sonex 892
VH ZSX
mike.smith wrote:I and some others have only gotten the wings to go together properly if you start with the RIGHT wing first. I don't know why, but we could never get them to go all the way in and align if we started with the left wing.
mike.smith wrote:But interestingly those Sonex instructions never explicitly say to start with the right wing. So anyone putting their wings on has a 50/50 shot at getting it "right" (no pun intended). And the issue hasn't been getting the bolts through, it's getting the wing spar to go all the way in so that the wing skin contacts the fuselage, signifying that the wing spars are fully overlapped. That seems to be what doesn't happen (at least more often than not) unless you start with the right wing. I had yet another builder confirm that to me today.
Users browsing this forum: No registered users and 46 guests
