N111YX wrote:Like many others I suppose, I utilized a inch or so of square aluminum bar pushed inside the frame member and secured with loc-tited countersunk screws. The pin is then tapped/screwed into this piece. It will be many times stronger.
N111YX wrote:That's one task in the plans that I just don't understand why it designed that way, Mike. It just seems too weak.
N111YX wrote:The only other one that comes to mind is the use of one pin for the gear leg fairings that are inserted from inside the fuselage. It's way better to use two that are inserted at the faring itself, not for strength, but rather convenience.
