Fibreglass Cowling
Fibreglass Cowling
Postby Corby202 » Wed Jun 24, 2015 2:21 am
I need to do some fibreglass work on my cowling. Did you guy's use polyester or epoxy?? I know the cowling is polyester but would prefer to use epoxy, just not sure how strong the joints will be.
Phil
Phil Bird
Sonex 759 JAB 2.2 Tailwheel
Mittagong NSW Australia
Corby202
Re: Fibreglass Cowling
Postby Gripdana » Wed Jun 24, 2015 7:11 am
I used West Systems which I believe is an epoxy. It did the job very well
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Postby kmacht » Wed Jun 24, 2015 7:33 am
I second the west systems epoxy. I did the whole horizontal split mid with it and the stuff worked great. If you have a boat supply place near you they usually stock it.
Postby sonex892 » Wed Jun 24, 2015 5:39 pm
Phil
Either resin will work on polyester. I narrowed the universal cowl quite a bit to better fit the Jabiru and used polyester for that. Its still good after 5 years.
sonex892
Postby Corby202 » Wed Jun 24, 2015 7:19 pm
Thanks guy's. Sounds like I should be ok using Epoxy.
Phil Bird
Corby202
