Hello Phil,
Don’t believe W&B is an issue but you can download an app from the Sonex Builders and Pilots foundation that helps with the CG calculations, it comes with a standard J2200 taildragger & nosewheel sample file which will give you a pretty good idea. You can download the app here:
http://www.americansonexassociation.org ... index.html(select the “Weight and balance program for your PC” under the “Downloads” dropdown list, then click “Go”)
So you’re in Sydney,
With all the hoo haa currently surrounding the Jabiru engines here in Aus, it could actually be a great time to pick up a low time second hand Jabiru engine somewhere.
It’s a little bit of a risk and so when negotiating a price you’ll have to take into account the fact that you will probably be faced with the cost of a mandatory SB coming up in the near future to satisfy CASA.
You’ve got to assume though they will eventually come to a solution, where some see risk, others see opportunity, if I were in the market for a Jabiru aircraft, engine, I’d be hunting hard right now.
