Sonex 772 wrote:Hey all
I am going to have to put a trim tab on my aileron, just wonder who else has done this and how big of trim tab is needed..
I also need to know if any one that has done this has any drawing or dims of the trim tab and how much it needs to be bent.
mike.smith wrote:I chose to put the trim tab on the outside of the flap, instead, and it's worked perfectly for me. I made a piece about 8" long, bent one edge, and stuck it on with duct tape. I would bend it more or less after my test flights, until I found the right amount. Then I riveted it in place. It's underneath the flap with the trailing edge of the trim tab aligned with the trailing edge of the flap, so you hardly see it when you walk past it.
gammaxy wrote:I'm not sure what the benefit of a trim tab on the flap rather than the aileron is. I think a much smaller tab would have a greater effect when attached to the aileron since it will be able to actually push the aileron up and create a greater rolling moment.
rizzz wrote:I think the idea is that much like a tab on the bottom of an aileron lifts the aileron, the tab on the bottom of a flap lifts the wing. Same principle no?
