Before I rivet the wing skins...
Posted: Mon Sep 08, 2014 12:52 am
Yes, I know I'm not the first guy to post along these lines... But getting the RH wing built has been a long time coming. Before I actually rivet the skins to my RH wing, could someone run down this list and let me know if I'm missing anything?
Here are the items I've done - any help spotting little items (or "tricks" to take care of with the skins still off) would be appreciated:
1) Main & Aft Spar assembled, all bolts tightened (spar mounting blocks only pilot-drilled)
2) Spars & ribs, all surface-prepped, assembled, & riveted together
3) Aileron bellcrank, assembled and riveted to the rib (along with stiffeners, ready to rivet to upper & lower aft wing skins)
4) Aileron pushrods, installed per plans
5) Wing tie-down hole drilled in lower skin (tie-down angle secured to main spar, but no tiedown bolt/nut yet - I'm assuming I can take care of this after riveting, with the inspection hole nearby for the Aileron bellcrank)
6) Snap-bushings installed & pitot-static lines run
7) Snap-bushings installed in all fwd rib tooling holes (nearest spar), with nylaflow tube running through them and 4-conductor shielded wiring inside of that (for LED wingtip lights)
8) Snap-bushings installed in all fwd rib tooling holes (nearest leading edge), with 2 tefzel wires running through the snap-bushings (protected with short bits of heat-shrink where they pass through snap-bushings) - these run to rib #11 for a Duckworks landing light
9) Duckworks landing light almost completely installed (missing final bits of tape to align second lens retaining strip)
10) Aileron and flap hinges complete
11) All holes dimpled (because I'm one of those crazy people going for a fully-flush-riveted aircraft)
Thoughts, suggestions, ideas?
Thanks!
--Noel
Sonex #1339
AeroVee Turbo (planned)
Pics: https://picasaweb.google.com/1039641523 ... SonexBuild
Thanks!
--Noel
Sonex #1339
