tonyr wrote:Root ribs done?
Wing walk and that annoying wing gap flange thing that I forget the name of, all drilled and countersunk.. the right way around?
Forward root rib centre flange removed ?
Bryan Cotton wrote:On the rivet sequence- is there any reason why I can't rivet the top aft skin and then the top forward skin before I flip it over?
Sonex1243 wrote:Wing tie-down hole drilled in lower skin (tie-down angle secured to main spar, but no tiedown bolt/nut yet - I'm assuming I can take care of this after riveting, with the inspection hole nearby for the Aileron bellcrank).
I had to upsize the piloted skin hole to allow the tie down bolt to pass through and mount on the angle. I had a wicks hardware kit tie down bolt, 3/8" shank with a wide shoulder, just traced it on the skin and up sized with a uni-bit.
NWade wrote:11) All holes dimpled (because I'm one of those crazy people going for a fully-flush-riveted aircraft)
