JohnBlackstone wrote:I've read a LOT of posts on tires and tire pressures. It's a little contradictory and confusing.
I'd like input on the Cheng Shin 11 4.00X5 tires.
I operate with wheel pants from paved runways in Texas, where pavement temps are hot for several months.
Various forums tout the advantages or disadvantages of various ply ratings.
Aircraft Spruce has Cheng Shin tires in 8 ply, 6 ply, and 2 ply. The 4 ply tire is tubeless.
Do we need 8 ply? Is 6 ply adequate? I've read of someone who is happy with his 2 ply,.
I wouldn't want to trade potential tire failure to save a pound or two per tire, if that.
Only about a dollar price difference between 8 ply and 6 ply.
Thoughts?
Bryan Cotton wrote:I'd be curious if anybody has thoughts on gear alignment. Not only what they think it should be, but also how to get it.
Area 51% wrote:
I guess you did a better initial alignment than I did. I was eating tires every 30hrs.
I eventually solved that issue as well as most of my shimmy by readjusting the toe-in. How that was accomplished was by reaming the attaching bolt hole up to 3/8in and at the same time moving the centerline of the hole a couple of degrees. Then I used bushing stock to bring the hole back to 1/4in.
I can send you a picture of the process if my description doesn't make any sense.
