Friesen5 wrote:Good Morning,
Does anyone have any experience using the Slick tires available from Great Plains? They can be found by clicking this link. http://www.greatplainsas.com/sctires.html
I'm interested in hearing how they fit in existing wheel pants, how they handle take off and landing, and how long they last in comparison with the Chen Shin tires from Wicks.
Mervin Friesen
Sonex 122
Jab 2200
235 hours
DCASonex wrote:Was just doing my annual and thinking time for new tires so seeing this conversation on the Slicks looked at Okeefe's website for those and noticed they also have the "sealed' tapered roller bearings which reminded me: Yesterday I Installed a set of those that I had purchased from Sonex. Big mistake as far as I am concerned. Aside from the fact that the extra thickness pushes the nuts out to where I would have to drill new holes. The added rubber layer each side made it very difficult to find the sweet spot that is just tight enough to eliminate all play without over tightening and the rubber seal riding on soft aluminum wheel just did not look like it would wear well. The give that results from the added rubber layers would seem even more problematic if used with Sonex hydraulic brakes that push from just one side. Removed them and cleaned and re-installed the old ones. The original large washers by themselves make a pretty good seal. Just wondering if anyone else had thoughts on these.
