Skippydiesel wrote:Still have about 100 mm up on trailing edge.
GraemeSmith wrote:Are the horizontal stabs actually airfoils? With one surface having more camber than the other? If yes. Anyvchance they got put on the wrong side and are "upside down" and generating "lift" the wrong way that is countering the angle of incidence? Like I say - spitballing.
Skippydiesel wrote:Area 51% wrote:If you're confident the wing incidence is correct, I would take a close look at the engine thrust line.
Full disclosure; This Sonex has had its wing/horizontal stabiliser, angle of attack increased by 1.6 degrees from factory/plans specifications.
Engine thrust line is defined by Sonex (factory) engine frame, with latest Sonex/Rotax "bed" adapter - I would hope that this would be well within design parameters.
Skippydiesel wrote:it should be 10mm (well under your 1/2 in).
gammaxy wrote:Skippydiesel wrote:it should be 10mm (well under your 1/2 in).
Okay, that doesn't sound as crazy as what I was picturing :-) I suspect most of us haven't measured our elevator deflection to that level of precision, but it's an interesting data point. Your measurement seems reasonable to me and I question whether you'd be able to measure the drag reduction of getting it perfectly streamlined. Do you have your wheel pants and fairings installed? Those have some affect on the pitch trim, but I don't know how hard it is to measure. As you explore more of your CG range, it will be interesting to see what that does to your elevator deflection.
