Re: Nose "heavy"
If you're confident the wing incidence is correct, I would take a close look at the engine thrust line.
A Forum for Sonex Aircraft Builders and Enthusiasts
http://sonexbuilders.net/
Area 51% wrote:If you're confident the wing incidence is correct, I would take a close look at the engine thrust line.
Skippydiesel wrote:T41pilot/Bryan C,
Very interesting - I have been working on the plans instructions; while keeping the control stick(s) vertical in a "jig", placing a straight edge on the aileron and measuring the "gap" at the wing spare positions. I then adjusted the flaps to the ailerons.
By any chance do you have a flap to spare gap measurement.
Skippydiesel wrote:...
Full disclosure; This Sonex has had its wing/horizontal stabiliser, angle of attack increased by 1.6 degrees from factory/plans specifications.
BRS wrote:Skippydiesel wrote:...
? Is this a common modification ? I can imagine this to be helpful for shorter takeoffs and better vsby on landing flair. What else does this accomplish?
