It won’t matter which leading edge you measure from as the difference is .125” at the most and that is level of accuracy beyond what matters. However, if you really want to get down to the nitty gritty just for the sake of the math, you could measure both and average. Just know that the it won’t matter as nothing on the Sonex is that critical.
gammaxy wrote:The Sonex wing chord (Mean Aerodynamic Chord or MAC--distance from leading to trailing edge) is 54". The 20%-32% utility CG limits correspond to 10.8" and 17.3" aft of the wing's leading edge (54" * 20% and 54" * 32%). You could use the leading edge as your 0 datum, but most people (everyone?) follow the example in the flight manual: http://www.sonexaircraft.com/support/manuals.html where the 0 datum is the tip of the spinner and is defined in the manual as being 53" ahead of the wing's leading edge. Putting the datum at or beyond the spinner makes it so you never have to mix negative and positive datum locations.
In this case, the forward and aft limits are 63.8" and 70.3" (10.8" + 53", 17.3" + 53") aft of the tip of the spinner.
To complicate things slightly, I doubt most people plumb bob from the tip of the spinner. They probably either use the leading edge of the wings or more likely the forward corners of the aluminum fuselage sides and add an offset to get the distances relative to the spinner (the fuselage corners are also defined in the manual, but I don't have my manual with me now, but it was the most convenient measurement for me to use).
STONE wrote:Thank you very much Chris.
Are the data you posted referred to the Sonex-B?
Mario
Skippydiesel wrote:I stand to be corrected - Datum point is just the point at/from which all measurements are taken/rferede back to.
You do not have to use the Sonex recommended tip of spinner (especially if not using the Sonex spinner).
In fact most homebuilts use the leading edge of the wing, in recognitions that there can be diffrent engined/propeller/spinner combinations.
