radfordc wrote:I repaired my tank using a simpler method. I removed the leaking fitting and drilled the hole out using a Uni-bit drill. I then tapped the hole using the proper size NPT pipe thread. I then screwed a brass plumbing fitting into the threaded hole. My tank hasn't leaked again in over 6 years.
daleandee wrote:radfordc wrote:I repaired my tank using a simpler method. I removed the leaking fitting and drilled the hole out using a Uni-bit drill. I then tapped the hole using the proper size NPT pipe thread. I then screwed a brass plumbing fitting into the threaded hole. My tank hasn't leaked again in over 6 years.
Charlie,
I like your method and quite surprised that no one else had tried it. If I need to make a change your idea sounds best to me. Not sure why the fittings were not threaded in like this to begin with ...
Dale
N319WF
