Re: Air speed off at low speeds
Posted: Fri Oct 13, 2017 6:25 pm
I gotta say something about the LRI. I built mine like you said except a friend tried to drill the long holes and couldn't keep the drill centered in the 1/2 inch material. I made mime out of 1/4 in pieces and cut a groove down both sides with a cutoff wheel to help the drill. I pinned and glued the two halves together after drilling. I adjusted the angle by doing stalls. It's a little simpler in a Onex. The weight doesn't vary as much. I use the LRI exclusively during take off and landing. It's a more accurate indication of air speed and attitude than the ASI.
