The latest on NavWorx & FAA, according to AOPA...
Postby airscribe » Wed Feb 22, 2017 4:40 pm
Reads like the FAA and NavWorx are nearing a resolution to the proposed -- but never finalized -- AD on the company's ADS600-B UAT...
Check it out for yourselves here:
[url]https://www.aopa.org/news-and-media/all-news/2017/february/15/light-at-end-of-navworx-tunnel?utm_source=eBrief&utm_medium=Content
[/url]
Hope it means relief for those of you hamstrung by this long-running dispute.
Dave
Waiex #216
AeroVee Turbo
N275AB reserved
Dave Waiex #0216
airscribe
Re: The latest on NavWorx & FAA, according to AOPA...
Postby WaiexN143NM » Wed Feb 22, 2017 11:11 pm
Hi dave, all
I dont think that is a click on link, i went to www.aopa.org. Click on news and media, scrool down below to right side youll see article. Patiently waiting for the out come.
Postby Jonathan McGee » Tue Jun 06, 2017 11:53 am
The FAA has finally published the AD. Basically, you need to either disable it or give it an external GPS source (the later option is probably the cheapest for those already invested). If Navworx modifies the firmware to report SIL 0 again, then it would also fulfill the terms of the AD but would not meet the 2020 mandate. And, on page 8, they specifically call out that this does apply to experimental aircraft.
It comes down to the use of a non-TSO GPS source (an off-the-shelf SiRF IV, which going through a couple owners, is now owned by Qualcomm) and claiming a non-zero SIL.
Attempt #2 at this whole Sonex Business.
Waiex-B WXB0019 [Progress reported upon completion]
Jonathan McGee
