outside air temperature probe
Re: outside air temperature probe
Postby mike.smith » Sun Jan 29, 2017 7:01 pm
I put mine through my windscreen. I drilled a small hole, have the probe sticking out in the air, and then sealed around it with clear silicone sealant. These pictures are before adding the sealant:
http://www.mykitlog.com/users/display_l ... 220&row=44
Postby Darick » Mon Jan 30, 2017 11:17 pm
Taking cues from all the responses, I decided to put it on the passenger side in front of the Naca vent, with a small half circle cover. Here is a picture before I finished putting the cover on it.
Most of the reason for locating it there was ease of wire placement on the inside. I'll add another wide angle picture tomorrow.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
