Re: N307TW’s Panel is finally done!
Posted: Fri Sep 17, 2021 8:33 pm
On a seperate note i see you have a trim servo breaker on the rear panel what kind of trim setup are you using?
A Forum for Sonex Aircraft Builders and Enthusiasts
http://sonexbuilders.net/
lakespookie wrote:On a seperate note i see you have a trim servo breaker on the rear panel what kind of trim setup are you using?
Murray Parr wrote:Looks like a lot of extra weight behind the seats. How do you think the weight and balance will go? I tried not putting anything aft of the seats as I think my cg will be farther aft with the Rotax up front
lakespookie wrote:AstroAussie wrote:Do you have pictures of your whole panel? Awesome work by the way! Maybe a youtube video if you ever have time or want to even? lol. I have been looking for panel ideas but they all seem to be A model panels so that doesnt help. I want the dynon system with the 10.5 screen as well. Maybe make it a ifr platform but very minimal IFR. I live on the west coast so getting into some coastal areas is difficult unless i wait till around noon for the layer to burn off. this is honestly awesome. great job!
I have priced out an IFR Panel, It will bring up the cost of the install and really depends on how much redundancy you want. But to set up a light IFR Panel i think the best option would be to add a single G5 about 1500 US and swap out the Transponder for the GNX 375 about 7k US, depending on the transponder solution your exsisting design includes you will save anywhere from 2-4k so your total increase will be roughly 6k to go IFR, less if you didnt have a GDL and were planning on the ADSB In transponder.
The Sonex Airframe is not ideal for IFR but i totally get the Marine layer issue in the mornings similar issue in SoCal and a reason i will be equiping IFR that plus i plan to fly across the country and it can be nice to be in the system for long trips like that.
AstroAussie wrote:lakespookie wrote:AstroAussie wrote:Do you have pictures of your whole panel? Awesome work by the way! Maybe a youtube video if you ever have time or want to even? lol. I have been looking for panel ideas but they all seem to be A model panels so that doesnt help. I want the dynon system with the 10.5 screen as well. Maybe make it a ifr platform but very minimal IFR. I live on the west coast so getting into some coastal areas is difficult unless i wait till around noon for the layer to burn off. this is honestly awesome. great job!
If you don't mind sharing, what panel ideas do you have? May i see your price out plan?
