steveald wrote:Mike,
I added a mechanical pressure gauge, but I'm not sure if I picked the right one.
http://www.vdo-gauges.com/instruments/by-series/mini-pressure-gauges/direct-mount-100-psi-mechanical-pressure-gauge-1-1-2-diameter-black-dial.html
This one goes to 100psi which is red line according to the Aerovee manual, is it OK to have the gauge pinned at the red line, or should there be more room? I saw a 150psi gauge, but it was larger, and I like the mini gauge as it only requires 1-1/2" of panel.
I can't think of any reason to not use the bottom oil cooler, unless it gets in the way of carb heat, which is mandatory in Canada.
Thanks again for the input.
steveald wrote:I can't think of any reason to not use the bottom oil cooler, unless it gets in the way of carb heat, which is mandatory in Canada.
