AOA
Mark’s latest safety posting:
Now I am confused (nothing to worry about- it happens every now and then).
A while back we had a few isolated cases in this country with people falling out of the sky, alas some fatal, although none Sonex. Since those dangerous LSA’s and the maniacs flying them are always in our authorities’ focus, the discussion about an approved mandatory audio stall warning device installation at least à la the ‘Cessna Switch’, in all LSA’s came up. It went so far that I had to get in touch with Sonex Tech with an inquiry about the installation of such a device in the Sonex/Waiex range.
Let it be said that I persoally hated the idea. Having all and sundry throttle jockeys hacking away at their wing leading edges for openings to fit the contraption, not to mention suddenly having som 400 aspiring test pilots falling out of the sky, was certainly less of a temptation.
To nobody’s particular surprise and my intense relief the answer came back that sorry, we can’t help, no research data available, no test installation completed, do not open up/puncture the wing structure- especially not the wing leading edge, etc, etc. Which all was what I wanted to hear.
BUT
Now Mark writes something along the lines of:……. This reinforces the need for all builders of homebuilt aircraft to install an AOA device, preferably with an acoustic signal…….
That’s news! Is this the new Sonex policy?
If so- is there anything available from Sonex, i.e. tests, recommendations, installation, equipment??
Thanks
Kai
BUT
Thanks
Kai
