Kai wrote:Check that the crankshaft has the smaller ø20mm prop flange bolt, and not the bigger one.
Get the prop dynamically balanced.
Find a proper place for the 4 cht sensors like shown on these pages previously.
Be very suspicious if you ever see the cht at anything much above 300F.
Check the ignition system for proper timing. When done, check it again.
Get hold of very high quality valves. If you´re not very comfortable with cutting seats and grinding in valves and seats yourself, take them to someone who is.
If the carburettor has a leaning device, always keep the A/F ratio below 12.5-12.8
Make sure that your cooling air plenum and baffeling is super tight. ALL the air must go where it cools- especially on the underside of the heads..
The exit lips on the air outlets in the cowling like suggested by Sonex must be in place. At least make them so wide that the the lower edge is flush with the bottom of the fuselage floor. Even better extend the cowling outlet channles back to the firewall. As an alternative you could also put side outlets in the cowling- mine made a real difference.
And finally- run the engine exclusively on good quality high octane fuel. Detonation will kill it faster than anything else.
Kai wrote:Get the prop dynamically balanced.
Kai wrote:Get hold of very high quality valves. If you´re not very comfortable with cutting seats and grinding in valves and seats yourself, take them to someone who is.
Hambone wrote:So, would you replace the valves that ship with a new head from Sonex?
BRS wrote:That prop spacer is what I was thinking would have to be done. 1" seems really heavy and overkill. A picture would be worth 500 words (inflation you know).
DCASonex wrote:Using my Dyna-Vibe balancer with a wood Sensenich prop on my CAMit 3300, was able to bring it nicely in balance by just adding some large washers under the nuts of the prop bolts. That was about 3 or 4 years ago, time to do it again.
BRS wrote:Really though, in flight it feels smooth, it's just that if there is something to be tweaked (in a good way) why spend my time flying when I can find a reason to be wrenching. Ha.
