Upper splice plates to cross tie box
Postby Bryan Cotton » Wed Apr 02, 2014 3:23 pm
Hi all,
The upper 3 legged splice plates have 3 holes that rivet to the cross tie box. The forward channel of the box seems to have the same 3 holes. If I didn't screw up again, those holes are not transferred through the upper web of the box when it is assembled. How do I proceed?
1) transfer the holes from the forward channel through the upper web and hope I can cleco to the splice plate
2) transfer the holes from the splice plate to the upper web and hope I hit the holes in the forward channel
Thanks!
Re: Upper splice plates to cross tie box
Postby Rynoth » Wed Apr 02, 2014 5:40 pm
I don't remember there being laser cut holes in the fwd channel where the splice plates hit. Might be why I missed the 40inch measurement issue.
Option 1 lets the prepunched holes dictate the position of the splice plates/longeron width. #2 let's you dictate position, with the risk of a less than ideal rivet hole.
Maybe do some more creative measuring to see if the prepunched holes put things where you want them.
Postby Bryan Cotton » Sat Apr 05, 2014 7:00 pm
Here is what I did. I ran the holes through the upper web that matched the splice plate. There were 4 on the forward channel and one on the aft channel (per side). Then I transferred the one hole from the splice plate to the middle of the web. I clecoed the box back in and found that the right side holes were lined up perfectly-ish with the holes I drilled in the longerons when I did the splice plate job. I always say I would rather be lucky than good. The left side was close enough. With a little flexing I was able to cleco it in.
On my next Waiex I will not drill the splice plate to longeron holes until I cleco in the cross tie box. Then it would be perfect luck or no luck.
I had a photo but my quota has been reached. Where do I put my quarter?
Postby Rynoth » Sat Apr 05, 2014 7:11 pm
I can't post pictures anymore either due to quota. :(
Postby Bryan Cotton » Sat Apr 05, 2014 7:52 pm
I have deleted some pics.
