by pappas » Sat Apr 09, 2022 7:55 pm
I flew my RV8 with a ram mount Ipad for 350 hours. I flew my most recent Waiex B model for 150 hours with an Ipad mini in a flush mount Guardian avionics Ipad mount. The mini had a small cooling fan supplied by Guardian.
Flying in southern Arizona, my experience was that both Ipads would overheat on the ground, (parked) if they were receiving direct sunlight from the rear of the aircraft for more than about 20 minutes or parked on the ramp for 30 minutes or more allowing the cabin to heat soak. (Assuming that the outside temp was 95 degrees or better.) I would have to cover the units with a towel for about 10 minutes to get them to cool down sufficiently to run again. I got in the habit of parking the planes with a towel draped over the units. There were no issues when parked in a hangar.
During flight, the ipads would overheat if strong sunlight was hitting them directly from the rear for 30 or 40 minutes if I was at an altitude of 2500msl or lower. If I was at 3500 or higher, The ambient air cabin temp was usually sufficient to eliminate the overheat condition.
Keep your ipads out of direct sunlight and avoid ground heat soak or you will have to cool them prior to flight.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
