Blake at Flyboys said no parts are available and the weldments are outsourced. In other words, you have to fix your tailwheel on your own.
This is not a big project. Fortunately, I had bought a 2nd hand TIG welder a few months ago and trying to learn how to TIG weld. This seemed like (and was) an easier weld project than the RV-6 gusseted rudder pedals I made last month. Here are the steps and some pictures of how to do this. It is a major improvement in taxiing capability. I can now do a 180 turn on the taxiway.
Here are the dimensions to make the angle change. The bottom length of the socket needs to be cut back to 2-1/8".
- Original & new Dimensions
- Tailwheel Change Dimensions Sm.jpg (127.76 KiB) Viewed 1741 times
After removing the tailwheel and taking it apart, the plastic bushings inside need to be pressed out with a 1" dia. rod and arbor press.
The socket is cut off the tube with a small cut off wheel. I used my Dremel with a 1-1/2" dia. thin cut off wheel that I bought from McM-Carr. A half round file after dremelling the socket to the new dimension get the socket to nest tight to the tube.
- Socket cut off from the tube
- Tailwheel Cut Sm.jpg (224.37 KiB) Viewed 1741 times
The socket and tube is checked on the tail spring and the end of the titanium spring had to be filed some reuse the same taper pin hole.
- Fit Check
- Tailwheel Fit Check Sm.jpg (110.48 KiB) Viewed 1741 times
The socket and tube are clamped on the spring and aligned with the fuselage. They are tacked in place to assure alignment.
- Ready for tack welding
- Tailwheel Cut & Clamped Sm.jpg (149.36 KiB) Viewed 1741 times
Once tacked together, the piece is welded. I still have a ways to go to get pretty welds but at least I feel comfortable they are sufficient to do the job.
- Welding complete
- Tailwheel Cut & Welded Sm.jpg (222.76 KiB) Viewed 1741 times
Then epoxy primer and paint to finish it up.
The plastic bushings are re-installed with the arbor press. Before I did this, I wire brushed and sanded out the weld crud from inside the tube. All the parts are reassembled and the steering rod I had made years ago is adjusted longer to fit the new positioning.
Total job including painting took me about 12 hrs. But then I am not known to work fast.
- Completed
- Tailwheel Modified Sm.jpg (130.35 KiB) Viewed 1741 times
Rick Caldwell
Xenos 0057 29.5 engine hrs + 3 hrs no engine
