Area 51% wrote:What I ran into was the lower cross tie (F-SNX-F24-05) pre-drilled holes were off and caused the overall width of the fuselage to be too narrow, not allowing the belly skin holes to line up with anything. Same factory pre-drilled 1/8in holes.
I re-made the cross tie and all was well. You can tell if this is a problem by measuring the width of the fuselage at that location. It should be 40in. Anything less will not allow the belly skin to fall between the side skins at the lower longerons. I've noted in the past that others have had to trim the belly skin to fit.
I still have the faulty cross tie in my "Hall-of-Shame" collection.
