T41pilot wrote:I'm looking for a best practice or easiest way of dealing with an oil leak at a cylinder base. I've got the jug pulled back about as far as I can without exposing the piston rings at this point. It appears that to do a proper job of cleaning off the old aviation gasket #3, that I should probably pull the cylinder all the way off and just completely clean off both the bottom of the jug including the shims and the block side and start over with a fresh install of sealer. I'm guessing I just didn't get enough on there when I built the engine or the cylinder got moved during the drying process and hosed it up that way. At any rate the leak was pretty bad. I'll probably do both cylinders since I have the engine torn down that far anyway. My question is can I use my ring compression tool with the piston still attached to the rod and reinstall the cylinder over the top of the piston or do I have to remove the piston pin and pull the cylinder and piston off together? It's been rather frustrating so far since I am so close to getting it certified and just having bad luck with oil issues. First an oil pump that was never drilled out and blowing oil out every orifice that it could find and now this. I've got another week of warm weather on the menu to try to get this back together so any help would be appreciated. I don't have any local buddies with VW experience to help.
Regards
pappas wrote:I just did exactly the same thing. Some people like Permatex aviation #3. I hate it! Smelly, drippy, runs all over the place and leaves ugly marks on the motor, really difficult to clean up. I'm out on #3.
I just resealed 4 cylinders with Hylomar Universal Blue. Awesome for me. Easy to apply, no leaks from the jugs or cylinder studs for the first time in 125 hours. Doesn't really harden and is a breeze to clean up even after it has set up.
I will never use #3 again.
pappas wrote:I have not had good luck with pushrod tube seals. I have put them in dry, with a light coat of oil, with RTV, with Dowsil 3145, and now with Permatex Ultra black for oil.
I recently installed them with Ultra Black on the seals and then "painted" the base of the tubes at both ends around the bottom halves of the tubes. So far, this has been the most effective method for me. Others have not had any problems with the standard methods. I replaced the original pushrod tubes long ago because I was tired of loosening the heads to replace seals. I now use EMPI spring-loaded tubes. If I have more trouble with them seeping, I will remove all of that and try the Hylomar Universal Blue. I like the way that has worked on the cylinder bases and studs. Experiment on!
Users browsing this forum: No registered users and 79 guests
