Murray Parr wrote:I had the same problem with the hardware call outs, most fasteners ended up with just 1 thread showing and failed the first inspection and I had to order on many occassions correct hardware from spruce. I also found the rivets supplied weren't near enough quantity. I have lost count of how many times I have ordered an extra 100 of most size rivets and still look like needing more. Freight gets expensive to Australia having to keep doing this. I love everything else about the Sonex, it would be great if they refined this.
Murray
Waiex B 0015
TW
Rotax 912 UL90% complete/90% to go
DCASonex wrote:Murray Parr wrote:I had the same problem with the hardware call outs, most fasteners ended up with just 1 thread showing and failed the first inspection and I had to order on many occassions correct hardware from spruce. I also found the rivets supplied weren't near enough quantity. I have lost count of how many times I have ordered an extra 100 of most size rivets and still look like needing more. Freight gets expensive to Australia having to keep doing this. I love everything else about the Sonex, it would be great if they refined this.
Murray
Waiex B 0015
TW
A decade ago, found just the opposite on bolt lengths, most were longer than needed requiring either short bolts or extra washers which would have been extra weight. Not counting the odd sizes, estimated about 11,000 rivets (A Sonex is 11,000 stainless steel rivets held in close flying formation by a minimum amount of aluminum.)
Users browsing this forum: Bing [Bot] and 87 guests
