Page 1 of 4
Instruction in Experimental Aircraft
PostPosted: Thu Jul 08, 2021 8:15 pm
by pilotyoung
In FAA-2021-0592] the FAA has announced a new policy regard instruction in experimental aircraft. Basically it says for an instructor to be compensated for the instruction in an experimental aircraft (not the use of the aircraft) both the CFI and the owner must have a LODA. There is a new electronic process to obtain a LODA.
This is pure stupidity!
I think every owner of an experimental aircraft should immediately apply for a LODA using the new procedure. Every CFI who gives instruction in experimental aircraft needs to apply for a LODA also.
Since I am both an owner and a CFI, I am applying for two.
The FAA does not have the people or time to perform the important tasks much less to create this mountain of paperwork that will accomplish nothing.
Re: Instruction in Experimental Aircraft
PostPosted: Thu Jul 08, 2021 8:52 pm
by pilotyoung
To follow up my last post I just submitted two e-mails to 9-AVS-AFG-LODA@faa.gov applying for LODA's. One was for an owner and the second one was as a CFI to give instruction in experimental aircraft.
I strongly encourage every owner of a Sonex aircraft to submit an application for a LODA this weekend.
My e-mails have not been returned.
PostPosted: Fri Jul 09, 2021 7:14 am
by GraemeSmith
How to apply:
EAA Newsletter wrote:Under the new LODA system, applicants can send an email to 9-AVS-AFG-LODA@faa.gov with their name, address, email address, pilot certificate number, flight instructor number (if applying as a CFI), aircraft registration number (if applying as an owner), aircraft make and model, and aircraft home base (if applying as an owner). The request will then flow to the local FSDO, who will issue the LODA. Both instructors and those receiving training will require a LODA. For aircraft owned by flying clubs, ownership groups, and other shared ownership models, the entity owning the aircraft may hold the LODA rather than each individual member. Either the owner/operator of the aircraft or the instructor can have the LODA, as long as one person in the cockpit has one. LODAs issued under this system will not allow rental of the aircraft to the general public. Those LODAs, issued for transition training and other targeted operations, will continue to be issued per the guidance in FAA Order 8900.1.
Note the contradiction between:
"Both instructors and those receiving training will require a LODA"
and
"Either the owner/operator of the aircraft or the instructor can have the LODA, as long as one person in the cockpit has one".
PostPosted: Fri Jul 09, 2021 8:31 am
by Sonex1517
I submitted my request last evening.
This is a terrible, horrible decision by the FAA and will decrease safety.
PostPosted: Fri Jul 09, 2021 8:46 am
by GraemeSmith
Sonex1517 wrote:I submitted my request last evening.
I agree - though I think they are "hoist on their own petard" and after "winning" a court case against an operator who was "possibly" bending the rules to suit themselves - they then opened a can of worms that didn't need opening.
Talking to friendly and safety oriented inspectors at my local FSDO - they are somewhat horrified by the actions of the FSDO that took Warbirds to court without checking in with National..... They don't want this anymore than we do.
If you read the full text of the policy:
"https://www.eaa.org/~/media/1091C7E251904915BBF431FC3EB9B628.ashx"
the LODA's can be issued by email AND the FAA consider this interim pending a regulation rewrite.
Not that it makes it any better in the meantime.
PostPosted: Fri Jul 09, 2021 9:06 am
by Jlogan1
I just applied also. lets see how this goes....
PostPosted: Fri Jul 09, 2021 9:59 am
by pilotyoung
Graeme,
and
The quoted language is from Graeme's post.
I went back to the actual FAA Notice. I thought this was from the Notice but it is from the EAA comments on the Notice. I agree this entire thing is confusing but when I originally read the quoted language, I took it to apply to aircraft owned by flying clubs and not aircraft owned by individuals. Time will tell what the FAA really means.
This Notice has really created a mess that the experimental community will have to sort out.
PostPosted: Fri Jul 09, 2021 12:49 pm
by Rynoth
Applied for my LODA. This doesn't seem like a big deal (other than the interim period of confusion) if the LODA is easy/quick enough to get, but time will tell on that.
Here is a link to the actual (officially not yet published) FAA document: https://public-inspection.federalregist ... -14765.pdf
Here is the format I used for the email application I sent, feel free to copy/paste and use it. Some fields may not apply, for example if you're not a flight instructor and just want to receive training in your aircraft or someone else's aircraft.
TO: 9-AVS-AFG-LODA@faa.gov
SUBJECT: Experimental Aircraft instruction LODA Application
I would like to apply for a LODA in order to provide transition/familiarity training in my Experimental Aircraft. (*change this wording to suit your needs*)
Name:
Address:
E-mail address:
Pilot Certificate Number:
Flight instructor certificate number:
Aircraft Registration Number:
Aircraft make/model in which you will receive or provide instruction:
Aircraft home base airport:
PostPosted: Wed Jul 14, 2021 10:58 am
by Sonex1517
Just a quick note folks.
I received my LODA this morning from the FSDO. I don’t think it was even a week since submitting the request.
I don’t envy the FSDO’s right now.
PostPosted: Wed Jul 14, 2021 2:04 pm
by Fastcapy
Holy crap Robbie. I can't believe it was that quick!
