MGL OAT Probe & GPS Antenna
Postby Stevetin » Sun Jun 20, 2021 4:00 pm
Hello Fellow Builders. I'm currently installing MGL XTreme EFIS & EMS in my Waiex. Any suggestions as to a location(s) to mount the OAT probe and GPS antenna?
Stevetin
Re: MGL OAT Probe & GPS Antenna
Postby garyb » Sun Jun 20, 2021 5:35 pm
Hi Steve
I mounted my GPS antenna on top of the glareshield and the OAT probe is inside the wing leading edge.
Regards,
Gary
Sonex #1531 Rotax 912ULS. 250 hours and counting.
garyb
Postby XenosN42 » Mon Jun 21, 2021 3:56 am
Stevetin wrote:Hello Fellow Builders. I'm currently installing MGL XTreme EFIS & EMS in my Waiex. Any suggestions as to a location(s) to mount the OAT probe and GPS antenna?
If you have a fresh air NACA vent feeding the cabin that is a great place for the OAT probe. It's easy to drill the back of the vent to insert the probe. Place the hole where the vent is deepest. The probe won't be visible, unless you look into the vent, and finally you you will get a very accurate outside air temperature measurement.
GPS antenna on the glareshield. You can cover it with the black cloth that you'll use to eliminate glare.
-- Michael
OneX N169XE
XenosN42
Postby Stevetin » Mon Jun 21, 2021 11:40 am
Thank you for your suggestions!
Stevetin
Users browsing this forum: No registered users and 81 guests
