Waiex rudder function?
Posted: Wed Apr 21, 2021 5:49 pm
How does the rudder function on the Waiex model...elevator vs yaw?
A Forum for Sonex Aircraft Builders and Enthusiasts
http://sonexbuilders.net/
sjakulski wrote:Thanks, Bryan. I think the V-tail looks cool. (In my deciding process) :)
pappas wrote:If you are going to be cool enough to fly a Waiex....you have to stop calling it a "V" tail! It is a "Y" tail because we have an actual rudder, as small as it is, at the bottom of the assembly. The shape, as viewed from the rear, is a Y. Unlike a Bonanza which is a V. The Bonanza has no separate rudder. That is the reason it is called a Waiex, (YX), version of the Sonex! At least that is my reason!
