Has anyone rigged up a switch to the canopy to detect whether it's closed all the way or not? It seems like it would be fairly easy and a good backup safeguard against accidentally taking off without it latched. I hadn't really thought of it until I was wiring up my Garmin stuff and found they had a preset you could use on one of the discreet inputs for a canopy switch, where it'll display a message anytime the canopy is open, and it'll generate an alert if you increase engine power with it still open. I'm sure it would be pretty simple to wire a light on the panel that's on whenever the canopy is open, alternately.
I figured why not, so I ran a wire from the Garmin box and just left it behind the seat to add later. I picked up this little limit switch, so now I just need to figure out where to mount it so it'll be out of the way and also catch the canopy right as it closes all the way.
- Canopy Switch.jpg (349.26 KiB) Viewed 2188 times
Has anyone else done this and found a good mounting spot?
