Extra Wing Fuel Tank
Postby Jgibson » Sun Aug 23, 2020 6:08 pm
Just curious: for those who purchased and are installing the extra tanks in the wings, how did the install go?
Any surprises? Was it as much or more work than you anticipated?
Anyone have photos of the tanks and/or installation progress?
Thanks in advance.
Joe Gibson
Jgibson
Re: Extra Wing Fuel Tank
Postby lpaaruule » Sun Aug 23, 2020 7:43 pm
It took longer than I expected, but that was mainly because I was very tentative. I should have just locked myself in the hanger for a couple days, and I would have had them installed.
The tanks themselves seem to be made well. I wish they wouldn't have come with any hardware, as some of it didn't get used. The transfer pumps provided allowed the main tank to drain into the wing tank, so I had to spend extra time and money to replace those.
It's nice having the extra fuel. I like not having to fuel up twice every time I fly somewhere that's a little over a hour away. However, since most of my flying is just short local flights, I kind of wish I would have used a removable solution. My plane now weighs 715lbs; my first flight without upholstery or wing tanks I weighed 663lbs. The plane performs great with them, but had I not set my gross at 1200lbs it would be a one person plane. As it is, I only fill the main tank if I have a passenger. BTW, at 1180lbs, and a density altitude of 2500ft, I still get around 800fpm at about 90mph. So the limiting factor isn't performance.
Bottom line is I'm satisfied with how the install eventually turned out. Hopefully I'll be able to get some long flights in and really take advantage of the extra range once the covid19 stuff is over.
I don't think I have any pictures, but if I find some, I'd edit this post and add them.
Paul LaRue
Sonex N454EE Plans# 1509
Jabiru 3300
First Flight 12/21/2017
lpaaruule
Postby Jgibson » Sun Aug 23, 2020 10:11 pm
Thanks Paul. Would really appreciate seeing some photos of the parts and install from you and/or anyone else who have accomplished or are in the process of installing the tanks.
Much appreciated.
Joe
Jgibson
Postby Carlos Trigo » Mon Aug 24, 2020 6:58 am
Who sells this extra tanks?
Carlos
Carlos Trigo
Postby Jgibson » Mon Aug 24, 2020 3:08 pm
A 'run' of tanks were made at one time for builders who committed to purchase them beforehand.
I will have a set made myself when the time comes.
Joe
Jgibson
Postby Jgibson » Tue Aug 25, 2020 6:59 pm
Waiex143NM: 2 p.m.'s sent.
Jgibson
Postby WaiexN143NM » Tue Aug 25, 2020 10:40 pm
hi all, carlos,
they are made by azelea aviation.(bill clapp)
i would just buy the basic welded tanks and finger screens. source all other parts yourself.
clean the tanks out good, i.e. dust and alum shavings.
Postby AlexZ » Wed Aug 26, 2020 6:36 am
Getting the tanks shipped to Europe would be costly. So making them over here saves some money. Are there drawings available? Or is it simple enough to make my own design?
Alex
Flying:
Sonex Legacy TD PH-AWX Aerovee https://www.facebook.com/SonexPHAWX/
RV-7A PH-PWP
Building:
Piel CP1320 https://eaabuilderslog.org/?s=CP1320
AlexZ
Postby Jgibson » Wed Aug 26, 2020 12:05 pm
I'd like to see a drawing with dimensions myself as I have a source to make me a set. The pumps, lines, etc are easy enough to spec ourselves.
Joe
Jgibson
