WesRagle wrote:Hi Guys,
On the forefront of my mind right now is gaining proficiency in my new Onex. The airplane is fun but will be a lot more fun when I'm not worried about the conclusion of each flight. I now have a total of 10 fights and 13 landings in the airplane and things are getting less tense but I still have a long way to go.
So, I enjoy reading all I can about the basics of takeoffs and landings from experienced Sonex/Onex pilots. I read the "Short runway and crosswind" and Jeff's "Custom Checklist Cards for the Cockpit" threads scanning for numbers, techniques, and rationales for pattern work. I'm looking for any tips I can find such as speeds, flap settings, xwind techniques, ...
Example:
While airborne the other day the wind went from basically nothing to about a 5 Kt direct cross from the left. That little hurricane off the coast was making the winds a little unusual for the area. That was more than enough excitement for me at my present level of proficiency.
Here's how the landing went. I rolled out on final and got a feel for the cross wind by crabbing for just a bit while coming down final. I then cross controlled most of the way down as necessary to keep the plane aligned with the runway while cancelling drift. I was too busy to look at the airspeed but have a suspicion that I instinctively lowered the nose and built up speed while slipping in for the landing. I spent a long time in the flair. It ended OK but I'm sure it wasn't a thing of beauty to watch.
So, is this the how you guys do it. Or, do you wait and kick the tail around as you enter ground effect. Or, ... Is it necessary to increase speed while cross controlled?
I should probably take the plane to altitude and answer these questions myself, but any knowledge you guys can impart would be appreciated.
Really anything at all concerning pattern work.
Thanks for Your Time,
Wes
fastj22 wrote:A 5 knot x-wind component is an excellent time to do a few touch and goes and get the feel.
fastj22 wrote:Although some may not believe it, I've landed (and took off) my Waiex in a 20 knot 90 degree crosswind. Most challenging of my aviating. The Sonex is a capable crosswind aircraft. I'm sure the Onex is the same.
Sonerai13 wrote: I once landed the prototype Waiex in a 25 knot direct crosswind because the customer that was with me had heard all the stories about the Waiex not liking crosswinds. it was work, sure, but it would have been in any airplane. The Waiex handled it fine.
WesRagle wrote:Anyway, another question. Do you guys fly different speeds on the various legs of the pattern or just set up for say 75 all the way around and then slow on the final approach? When do you deploy flaps and how much? I only have half and full flaps.
MichaelFarley56 wrote:Joe, when you are flying your Sonex (or when you were running T-Flight) did you teach students to land flaps UP in crosswind situations?
MichaelFarley56 wrote:And, while I don't mean to hijack this thread
