Rofomoto wrote:On my final stages here. Last thing is my aileron push tube attachment. Is the 5/16 od bushing Supposed to turn with the push rod assembly tube snx-c03-2? Or is the bushing stationary and the push rod assembly tube turn on the outside of the bushing ? Thanx billy
Rofomoto wrote:So the powder coating is to be removed from the 5/16” hole in aileron control tube correct? The bushing in the control rod should be able to rotate.
sonex892. wrote:Rofomoto wrote:So the powder coating is to be removed from the 5/16” hole in aileron control tube correct? The bushing in the control rod should be able to rotate.
Thats correct
NWade wrote:A 3/8" long bushing is called out on the plans, but if you measure the 1/2-scale detail drawing you'll see that the drawings show it as only 1/4" long! This is so that the narrow end of the flanged bearing is flush with the bronze washer that sits between the aileron pushrod and the bellcrank.
I'd manually shaved my bushings down to roughly this length and assembled the system, but in recent checks (as I near first flight) I noticed that mine were still a few hundredths of an inch too long and I didn't like the slop that left in the connection with the bellcrank so I've ordered some1/4" long flanged bearings from McMaster-Carr that should be the exact right specs. I'll post an update as soon as I've gotten them and checked the fit!
