Securing things in the engine compartment
Postby Spaceman » Wed Jul 22, 2020 11:04 pm
What are some methods you guys have used to secure various things around the engine?
Seems like zipties are kind of frowned upon sometimes although they are probably the easiest for smaller things. On the other end of the spectrum there's adel clamps, but they're probably overkill for a lot of stuff! What else is there?
So far I've used adel clamps to mount some large things like the oil separator and turbo cooler radiator. I have all kinds of small wires temporarily ziptied to the engine mount, but I'm debating if I should use something else. Then I have some medium size things floating around (oil hoses, throttle/mixture cables, spark plug wires, etc), that I'm not sure what to secure with yet.
Anyone have any good tips?
Thanks!!
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Re: Securing things in the engine compartment
Postby wlarson861 » Wed Jul 22, 2020 11:56 pm
Zip ties are great for securing wires and small hoses to the engine mount. However you must cover the contact area with silicone tape to prevent the zip tie from wearing into the material. My DAR said he did an annual on a Cessna that had a Zip tie wrapped directly to the steel motor mount tube, over the years the zip tie had cut into the metal so far that failure was eminent.
This the stuff; you can also get it at most home centers:
https://www.amazon.com/Self-Fusing-Silicone-Weatherproof-Electrical-Emergency/dp/B07MZK3XSD/ref=asc_df_B07MZK3XSD/?tag=hyprod-20&linkCode=df0&hvadid=366402165032&hvpos=&hvnetw=g&hvrand=10923100277729546320&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9022121&hvtargid=pla-855747702407&psc=1&language=en_US&tag=&ref=&adgrpid=79101501827&hvpone=&hvptwo=&hvadid=366402165032&hvpos=&hvnetw=g&hvrand=10923100277729546320&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9022121&hvtargid=pla-855747702407
Bill Larson
N861SX
wlarson861
Postby Spaceman » Thu Jul 23, 2020 12:49 am
Oh yeah! I forgot to mention that. I did pick up a roll of that same stuff from aircraft spruce. Seems real handy. I've been wrapping it around the motor mount wherever anything could potentially chafe against it. I only heard about that stuff recently and I'm glad I did!
Chris Paegelow
Spaceman
Postby Onex0029 » Thu Jul 23, 2020 11:49 am
Mike and Mark Patey sell a rubber lined zip tie that would alleviate the chaffing issue. They own Best Tugs.
Onex0029
