Page 1 of 2
lexan
PostPosted: Thu Apr 30, 2020 7:58 am
by Area 51%
I've got some sticky residue from tape on the windscreen. What can (or can't) be used to remove it?
Dawn doesn't do it.
Re: lexan
PostPosted: Thu Apr 30, 2020 8:36 am
by T41pilot
WD40 is reputed to remove glue if you let it sit for a little bit. I used mineral spirits before too on the aluminum part labels. Same thing. It has to sit for a minute or two. Hope you have some scrap left over to try some ideas.
Re: lexan
PostPosted: Thu Apr 30, 2020 8:51 am
by Area 51%
While fitting the windshield bow, I saw I was wearing through the protective film on the Lexan, so I protected it with shipping tape. That's the adhesive residue I'm trying to remove.
I wiped a scrap piece with lacquer thinner a half an hour ago. There are no short term effects. Long term crazing might be the issue.
The international symbols on the protective layer shows I'm not supposed to pour anything out of a test tube on it. Only slightly vague.
Re: lexan
PostPosted: Thu Apr 30, 2020 9:17 am
by SonexN76ET
Try some high quality automotive wax and gently rub it out.
Jake
Re: lexan
PostPosted: Thu Apr 30, 2020 11:27 am
by pappas
I have used Goo Gone on plastics and rubber without side effects. It is pretty mild. As always, test on a piece of scrap.
Re: lexan
PostPosted: Thu Apr 30, 2020 11:55 am
by Area 51%
That's the problem with trying anything that doesn't have a history with Lexan specifically. Thinner didn't seem to soften the material, but who knows about it long-term. I did use Goo-Gone, and it worked well, but it's a little troubling the directions require removing the Goo-Gone with hot water and soap. What happens if you don't get it all?
Too late now. If there's some kind of reaction, I'll keep you posted.
Re: lexan
PostPosted: Thu Apr 30, 2020 3:35 pm
by Gordon
Goo Gone
I have used Goo Gone with good results at removing residue and no harm was done.
Using lacquer thinner, MEK, etc is fine on aluminum but will attack the plexi and lexan.
Gordon....Hummel 2400...…..Onex.
Re: lexan
PostPosted: Thu Apr 30, 2020 5:03 pm
by sonex892.
Eucalytus oil is great at removing tape or sticker gum. Its definitely safe to use on perspex, not 100% sure about lexan, but it would be the first thing I'd try.
Edit
Just removed a bit of dried up tape gum with this stuff on my own windscreen. it worked fine and doesn't affect the lexan.
Steve
Sonex 892
Re: lexan
PostPosted: Thu Apr 30, 2020 5:27 pm
by dtwolcott
I have had good luck with using peanut butter for removing label glue. rub on and let set overnight and try to rub off with terry cloth the next day.
Re: lexan
PostPosted: Thu Apr 30, 2020 5:44 pm
by Area 51%
dtwolcott wrote:I have had good luck with using peanut butter for removing label glue. rub on and let set overnight and try to rub off with terry cloth the next day.
I thought you were going to say the mice will lick it off overnight.
