Straightening bent gear legs
Postby Fritz » Wed Mar 04, 2020 6:53 pm
Hi All,
I've heard of people straightening bent gear legs on a Sonex/Waiex. Has anyone here done it or have any suggestions on where to find someone who might be able to do it?
I'm really trying to avoid having to drill a new set of gear legs.
Fritz
Fritz
Re: Straightening bent gear legs
Postby tx_swordguy » Wed Mar 04, 2020 7:40 pm
have absolutely no experience but would think a machine shop would be able to accomplish that for you unless they are severely bent. I would think they could press the majority out and once they got close roll it to find the high spots or dial it in a lathe once it was close. I would not think it needs to be accurate to .0001" because they will flex independently according to load.
Mark Whiddon
T25 Aero Estates
Sonex N889AP
jabiru 3300 solid lifter
tx_swordguy
Postby sonex1374 » Wed Mar 04, 2020 11:22 pm
Several people I know have straightened bent gear legs using a hydraulic press. In one case a 30 ton press was used, in the other a 10-ton was sufficient. In any case, it takes a lot of oomph, but is rather uncomplicated.
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Postby peter anson » Thu Mar 05, 2020 6:53 am
Yes, have done it and it's not too hard to do, as long as they are not bent too much. When motorcycle front fork legs were skinny thick walled tubes it was quite common to straighten minor bends using a hydraulic press. These days most bikes use larger diameter thin walled tubes which tend to kink so it's probably not done as much but I would guess that many motorcycle repair shops could do them for you.
Postby Mark_Souza » Thu Mar 05, 2020 1:15 pm
Just a word of caution. The metal has deformed once, which means it's been weakened. Straightening means deforming it a second time (more weakening). It might work fine for uneventful landings, though surely the number of cycles you can count on the legs has been reduced. How much? You'll never know. And for a hard landing, will it deform next time, or give way?
Mark_Souza
Postby Msing48 » Thu Mar 05, 2020 7:39 pm
Robert Barber said he can straighten them for you. He has done it a couple of times.
Msing48
Postby fastj22 » Thu Mar 05, 2020 8:02 pm
In my off field landing, I bent my Tracy Obrien steel legs slightly. He told me they could be rebent using a hydraulic press without an issue. I used the excuse to buy the 20 Ton press from Harbor Freight. Cut a vee holder out of a 4X4 chunk of scrap lumber. Did it in small increments. I assume you could do the same for the titanium legs, but might need more press.
Postby Msing48 » Thu Mar 05, 2020 8:05 pm
Msing48
Postby Fritz » Thu Mar 05, 2020 10:03 pm
I sent Robert a PM. I'll see what he says.
Fritz
Postby Fritz » Thu Mar 19, 2020 11:55 pm
Just a quick update: Robert Barber did a fantastic job of straightening out the gear legs. They went back in without a hitch and fortunately they don't appear to be twisted.
Thanks again Robert!
Fritz and the gang at Chapter 555
Fritz
Users browsing this forum: No registered users and 87 guests
