Random Observation
Posted: Mon Aug 19, 2019 12:39 am
Hi Guys,
It's been over 100 deg. in the shop for days now. So, I seem to end up in the house thinking a lot more than out in the shop doing. This evening I found myself sitting in the air-conditioning looking at this assembly and thinking about all the fuel leaks that have been reported in the past.
While opening and closing the valve it occurred to me that the root of the problem was probably the valve handle. If you imagine putting your pointer on the tip of the handle and moving it to the open position while considering what is happening at the threads going into the tank to counteract that force/torque, it's not good. One side of the threads is in compression and the other side is in tension. It's a lot like what you would do if you wanted to start a leak. Screw a pipe into the fitting and wiggle it side to side.
Now think about what would happen with a properly actuated T-handle. The only force present at the tank inlet would be perpendicular to the bore of the fitting. That is to say it would just press on the side of the fitting instead of trying to wrench it out of the tank.
Anyway, just a thought. Since I like simple, I think I'll go with a tee handle and try to get it past the DAR. I know from experience that I can remember where the fuel valve is, without looking, after just a few on/off cycles.
Wes
Wes
