DCASonex wrote:Every cracked canopy i have seen (Including mine) the cracks originated along the lower edges of the sides. The standard Sonex "A" model canopy is curved on the sides and when pressed into shape along the straight edges, the inside surface is under tension. Any tiny scratches or nicks along those lower edges, especially if on the inside will result in cracks. Unfortunately the Todd's canopies that had nice straight sides are no longer available. Folks that have had the best success with Sonex canopies seem to install them on very warm days.
Rickadler wrote:John Gillis- Can you send us photos what you did with the angle on the bottom. Thanks in advance.
Screws and nuts were used and not more than finger tight and oversized holes through the plastic.
