Sonex Builders Checklist
PostPosted: Wed May 15, 2019 3:48 pm
by N418SX
We picked up a fuselage kit Sunday with Plans #1710. The seller did not have the Sonex Builders Checklist book. A search of the Sonex website and Google did not produce anything. Does anyone have a copy we can borrow to duplicate?
Re: Sonex Builders Checklist
PostPosted: Sat Oct 19, 2019 6:14 am
by Mikegaydos
I too have a need for this, particularly at the drawing level. Please let me know if you find anything.
M
PostPosted: Sat Oct 19, 2019 6:57 am
by sonex1566
I don't think that it actually exists! I believe that the plans contain all the info you need. I know that this may cause your head to explode but the system does work. I'd been building for a couple of years before discovering that there was a material planning guide! I cut my parts out completely different from what was suggested and only ended up purchasing 2 extra sheets, one of those was due to being a complete numpty when making the leading edges for the wings.
Good luck, I recommend more coffee and head scratching.
PostPosted: Sat Oct 19, 2019 4:47 pm
by Rynoth
The building tree page in the blueprints(plans) basically IS the checklist. You pick the bottom of a branch and work your way up through the pages.Eventually it will join another branch, which also needs to be completed (bottom>up) before you can proceed from where they join.
I cut out the building tree page and stuck it on the wall. I would x off each box on the tree as I completed the pages (and usually added the date for posterity) and eventually you end up at the very top box, Aircraft Complete!
PostPosted: Mon Oct 21, 2019 8:36 pm
by N418SX
Actuall it does exist. We found one less than 40 miles from our hangar.
