wing-to-fuselage gap
Postby Area 51% » Tue Jan 29, 2019 2:21 pm
Just completed the wing rigging. Bryan Cotton's method worked like a charm. (Yes, I have drill bushings available)
Now for the root doublers/wing-walk. Based on the gap given on the print (1/32 to 1/16), I don't see any way to get a piece of rubber trim between the wing and fuselage. Even if installed before the wing is attached, it seems the trim would keep the wing too far away from the fuselage.
What are you using, and how much of a gap do you need?
Making airplane noises louder and louder here @Area 51%.
Re: wing-to-fuselage gap
Postby Bryan Cotton » Tue Jan 29, 2019 3:24 pm
Prior thread on the subject:
viewtopic.php?f=21&t=2799&hilit=Thx+bob
I still plan on tape. Thx Bob for the trim technique!
Postby Concorde » Tue Jan 29, 2019 8:56 pm
I made mine 3/16” for the RV rubber gap seal.
Ben
Sonex # 1684
Tri-Gear, Dual Control
Rotax 912uls
N379BS reserved.
Concorde
Postby Area 51% » Wed Jan 30, 2019 2:08 pm
Any chance you could post a cross-section picture of the Van's seal? Everything I've seen resembles the Piper seal. Thanks.
Postby sonex892. » Thu Jan 31, 2019 12:26 am
Here you go. This is ACS rubber, but virtually the same profile as the vans. I used a 4mm gap.
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby Area 51% » Thu Jan 31, 2019 8:45 am
Nice.....Thanks much!
Postby lgsievila » Fri Feb 15, 2019 12:53 am
This is what I did on my Onex-not my idea but thought I would share. Used SEM 29372 which is used in auto body repair. Available on Amazon or your local auto paint store. Been working fine for five years now
https://1drv.ms/a/s!AsAj3XbiLtyNmTQUitN-UDFTrufb
Loren Sievila
Conventional Gear Onex33
CAMit 2200
Dynon Skyview
lgsievila
Users browsing this forum: N265DF and 22 guests
